cantcatch06
Active Member
- Joined
- Oct 9, 2008
- Messages
- 44
- Reaction score
- 0
Speedometer started jumping while drive down the road. At first it was only at freeway speeds and progressivly got worse. Removed speedometer cable and lubricated with powedered graphite. Same jumping problem as before. On way to work the next morning halfway there started jumping Excessivly then the needle broke off, Broken part of needle jumping even worse then before for another mile then nothing. Remove speed cable and replace with new one, old one was twisted off near the transmission. Removed speedometer and replaced with a spare from a busted cluster from another car. Carefully cleaned by hand, lubed, polished etc.. On way to work this morning noticed a slight shimmy at speed less than 5 miles total fluctuation. Figured it was just a sticky cable because it was new. At lunch more graphite in cable. On way home same road as before... same thing happened. Starts jumping BAD then the needle breaks off. Less than 5 min passed between when it started jumping the second time and the needle breaking off..
My question:
is it possible i've got a bad speedometer gear causing my problems?
Also has anyone had any luck fixing a broken needle?
If not any guess where to find a speedometer for a 66 barracuda?
My question:
