Just finished up yesterday, adding AC to my neighbor's son's house. This was a "got my *** kicked" deal. The furnace closet is ridiculously small, with almost no room for anything larger in the way of a furnace or water tank. Whoever designed that should have their *** kicked
Today it let me know "one last time"
Whoever installed the stat wire at the time the house was built, evidently snagged it on a duct "somewhere." This is all built into the house, you cannot get to any of it without cutting into ****. "I thought it was odd" that the green blower wire which was stripped at the furnace terminals, was not connected. (This is connected without AC a lot so you can have a "summer fan.") Turns out the white (heat 1) and green (blower) are shorted together. Also turns out the yellow (for the AC contactor) was SHORTED TO GROUND. Managed to blow the 24V fuse on the control board for my trouble. FORTUNATELY it is a 6 wire cable, and there were 4 clean wires, just wrong color
A few other minor "gotchas." The cheap China no-name sold-under-40-other-brand-names equipment--- The service valves are not particularly well mounted, and it takes considerable force to open the valves. Also the 1/4 flare schrader access ports are so close to the sheet metal lip, that it's difficult to get your finger sin there to attach/ remove the gauge fittings. The suction fitting on the coil is a real POS. It "acts" like it is set up as a female for a 1/2" line. you slide a 3/4 el onto it and it's REAL sloppy. And the swadge is so short that the el overlaps it, making brazing a POS. So I cut off part of the sleeve on the el to keep some of the larger area of the nipple exposed. REALLY poor engineering.
Ya know guys, much of this equipment looks very similar to the stuff I routinely installed and serviced back in the 80's/ mid 90's. SO WE DIDN'T START MAKING THIS **** RECENTLY. There is no ******* excuse why this stuff cannot be well made and designed.
I just turned 74 by the way, and this **** gets harder by the month LOL
I did not do the sheet metal work. You can see some of how tight this is, and worse, the furnace is "over in the corner" so to get my head in where I could see the controls (in bottom of furnace) I had to "fetal up" with my knees banging the water tank and my back against the door jam. No fun at'all.............
I've done nicer work on the outoor stuff, but that soil is rocky as &*%% and I wanted room for access between the unit and the irrigation controller. Because of the tight stuff in the furnace room, we had little choice for tubing entrance
