Just learning
amp1956
Member
texas
I have a 66 charger I need to know if the disc set up on a,79 New Yorker will fit I know there are kits but I have a k member off the 79 complete and not sure if it has been done. Thanks in advance
73 to 76 A body setup from spindle out.
If the 79 yorker is a C body with the 11.75" discs, then just use 73-76 dart spindles, and use everything else off the 79 yorker from dust shields out. Including caliper mounts, mount bolts, calipers, rotors. All this fits on the dart spindle which fits on the 66 charger upper and lower ball joints. You need the 79 yorker master cylinder too, as this has a bigger piston to port fluid to the bigger 2.75" caliper pistons off the 79 yorker.
This will add big brake discs to your charger.
Sorry for delay had family emergencies but thanks for all the info I don't always remember to check back now all I got to do is find spindles
