Jan 17, 2011 #1 S slx70 Well-Known Member Joined Jan 17, 2011 Messages 82 Reaction score 13 Location ohio I have a 1970 dart with a 6 cylinder k-fame. I have a 1969 340 that i want to install. I bought a v-8 k-frame form a 1973 dart that has spool mounts instead of flat mounts that come on a 1970, will this work? Thanks.
Jan 17, 2011 #2 S SonofaHatchet Well-Known Member Joined Jan 12, 2011 Messages 114 Reaction score 0 Location neverland Yea it should be all good Nate
Jan 17, 2011 #3 autoxcuda Well-Known Member Joined Apr 6, 2007 Messages 9,536 Reaction score 5,076 You need to put some spacers on one of the drivers? side motor mount to block bolts. You can use the 1969 /6 steering box, pitman, idler, and center link with the new K-member all as a unit in the 73 spool K-member.
