K frame question
Slappy
Tampa Fla.
Will a 72 dart kmember work in a 73 Dart? I know the motor mounts are different. Can you put flat type mounts in a 73 as long as the k member is changed to fit the mounts?
The engine blocks did not change, so if you have all associated hardware it's a bolt in swap.
There was a steering linkage change in 73 as well. It is best to run the same year center link, idler arm and pitman arm as your K-member.
