K-frame removal
Nu2Mopar
NorCal
i know that there has to be a sticky somewhere, but I'm lazy....lol
what is the easiest / safest way to remove the k-frame from my car (70 duster). The engine / trans are out of the car and I want to clean, paint and rebuild the suspension...so what are the proper steps to take for removal?
Thanks,
Back off T/bars and remove,remove shocks,brake lines. Separate ball joints,separate stearing colomn,remove the 4 bolts that hold the member on and I beleive that should do it.
That should do it. and back off T bars, Take them out, Unhook stearing colomn, Take of the top bolt of the shock and the upper controle armes, unhook brake lines, remove the 4 bolts in the K frame.
