KB Performance Pistons ?
Plymouth 65
I'll be in the shop
Mich
I'm considering using Keith Black Performance pistons in a mild street build 440, 10:1 CR. What's your experience and opinions of there pistons? What about the high upper compression ring? Thx, 65'
I have had a lot of luck using KB in SBC circle track motors. Follow the instructions for the top ring, and never had a problem. They run the top ring high on the piston, so gap has to be opened up to compensate.
Used in 2-360’s and 1-340.
Excellent piston for the intended purpose. Street/strip high performance usage.
I run them N/A.
Timing is everything!
Ring gap is critical.
