Wademetzinger
Used but in good shape, Keith Black Cast Aluminum Oil pump. 2 lines go to the pick-ups in the pan and the other 2 go to the remote oil filter adapter. This one has been setup for non-blown application by removing the inner spring in the pressure relief to support 75 95 lbs of pressure rather than the 150lbs they make with both springs, so this will work in anything from a 600hp bracket motor to a 1,600hp shoot-out motor or buy a new spring from KB and use it in a blown application.
Also comes with new rebuild kit, o-ring/seal kit received from KB just this week.
These are $750 new from KB, Ill take $350 shipped for this one.
PayPal accepted
PayPal accepted
