I rebuild brake and suspension parts as a little side line business, and i just finished up rebuilding this 65-72 A body Kelsey Hayes disc brake set up.
Calipers have new pads,new rebuilding kits, new rubber brake hoses, and all the hose brackets, and pad hold down clips, caliper hard lines are all there.
Rotors are new. All the lug studs are right hand thread. All the wheel bearings, grease seals, are all there.
Everything has been thouroughly cleaned, then soaked out in a solution of Evaporust, then painted up with Rustoleum paint, and put back together.
Included is the disc brake proportioning valve, and the hard lines to the master cylinder.
This is a complete set up, but you will need to purchase your own DISC brake master cylinder to use these disc brakes, wether you buy one for manual brakes, or power brakes, that will depend on what you will be using.
Also if your existing lower ball joints are in good condition, you will have to drill out the mounting bolt holes to 9/16 inch, or purchase new Disc brake lower ball joints.
Selling everything for $775.00, plus what it costs for boxes, and the FEDEX shiping to your zip code. Price is firm. I spend lots of labor time hours to rebuild these parts, and what it costs for parts.
Have plenty of other pictures that i can send to you, if you are a serious buyer for my parts.
This is the current set up that i was putting together for sale.
Contact me through this forum with a PM message.
Thank's
Jim V.
Thank's
Jim V.
