Does anyone have a recomendation for brake pads for a Kelsey Hayes disc setup, just did the conversion on my 68 Dart the car is street legal but gets little street use. Do the organics stop good or is that all that is available?
Just goes to show you that you can learn something every day.......I didn't know Dan has a sense of humor..... ....just kidding! I know it used to be that I'd use the softest pads I could find for those KH brakes because the rotors were so hard to find. Now, with the cheap replacement rotors, I may try some of the semi-metallics or ceramics to see how they work/feel.Pad composition has a large effect on pedal effort. I don't run a booster, so I prefer a softer organic brown pad rather than a harder semi-metallic black compound. These have grown harder to find but can still be turned up if you dig. Last set I installed in my '62 w/KH brakes was New Old Stock Mopar, which made the pedal effort a great deal more appropriate (it was ridiculously stiff with the previous Raybestos ones).
You might check with Old Car Parts Northwest and see what they have on the shelf; ask for pads for a '71 Dart.
Once you have your pads in hand, cook 'em in an old toaster oven to make bed-in much faster and safer once they're installed. A couple hours at 350°F does fine. The other trick I've used to improve disc brake performance on this system is to slot the pads anglewise, dividing the brake pad surface in three with two diagonal slots (aft inboard to fore outboard — pay attention to inboard vs. outboard and left vs. right pads) cut with a hacksaw after putting masking tape on the pad surface. WEAR A DUST MASK and otherwise do asbestos you can to keep dust down (get it? Asbestos you can? Haw haw haw)
