terzmo
where or is there a source for parts to rebuild kelsey/hayes caliphers ??
Thanks in advance to all
only thing you need are the $4 rubber seals? Pistons are a non wear item. If one piston is frozen, take caliper off disk and put a socket between the pair of working pistons and apply brake pressure, the other will pop out. If you take them apart, make sure you use the proper bolt or a grade 8 bolts to put them back together.
