coloradohill
I have a 6 qt. Kevko oil pan M301KO for small blocks. (7Qts. Total)
Dyno time only, the website says you may have to notch the K frame to fit.
I have a spool mount K frame and the pan is 1/4 inch too wide.
A older K frame or aftermarket type may fit. ( I could not remove any more material between the mounts.
My builder had to bend the crank scraper slightly for clearance to the girdle. It can be straightened easily.
It measures approximately 11 1/2” wide without the drain plug and 12” to the drain plug.
The spool mount K frame is 11” between mounts.
They are priced at 440.00 plus shipping.
I’ll ship it in the lower 48 for 380.00 total.
Website link
M301KO318-340 Stock Location
Website link
