[WANTED] kick down linkage
pyrojim
Chesterton, Indiana
Need a kick down linkage set for a 1966 dodge dart 273 motor (now 318 ) floor shift. Not sure but I think its 3 piece.
I have the swivel that bolts onto the head.
Thanks.
Jim
Not sure which is the right set up. Basket case car I'm piecing together.
318 with 360 heads. Edelbrock performer intake. 600 AVS carb.
Which would be not be necassarily the correct one. But the right one??
Well, in order to use either one, you need all of the corresponding linkage for each setup, as they are both different! The most important piece to either setup is the carb linkage, which has a unique bend for the 4 bbl carb. I would hit up 2manymopars, sounds like he can get you the entire setup! Either wi work with your combo provided that you get every piece in the assembly! Geof
I think this is the correct set up. I've mocked it up, seems right according to the manual. The linkage that goes to the carb runs true and straight. Problem is that it's worn out at the threads. Again, this was a basket case I'm trying to piece together. I may be barking up the wrong tree??? As always, thanks for the help.
Jim
