[FOR SALE] Kick down linkages
Any 383/400 A body? Gonna need it all. I’m going 451/727 in my 67 A body. Thanks Kim.
Third from the left, with the return spring bracket.
How much Kim ?
Thanks
1970 340/727 with column shift automatic. I’m missing everything related to the throttle linkage assembly and kick down. Also in need of all of the shift linkage. Thanks
Hey Kim here are the pictures of my setup, it's a Holly 4776S. I don't think you can tell from the second picture but the upper rod is on a slight angle from the back to the carb stud this is why I think the rod I asked you about will work.
Thanks
Bob
Hey Kim some more pictures. I was thinking about just bending that rear bracket in picture two so the upper bar is strait in line with the carb stud and then maybe just welding on a small piece of steel on the bottom of the upper arm for the return spring.
Bob
Is the 3rd one from the top or the one all the way at the bottom still for sale? Need it for a four barrel swap for my dart 2barrel with 904 tranny. Looks like the right pieces. Thanks
