speedyb-cc
speedyb
I can't believe it after three years and 5 carbs I finally found the sweet spot. It stays in 1st up to 20-25 mph with minimal throttle and in 2nd up to 35-40, kicks down almost immediately, has full throttle, and shifts real firm. I'm using the intake and Q-Jet from the 86 360 I bought to rebuild. The Q-Jet also has the solenoid that is activated by the compressor clutch wire which helps alot when idling in traffic with the a/c on. IF it keeps working this good it will go on the 360 when done.
Bruce
Bruce
