kickdown?
MI_Mopar
Ann Arbor MI
so could i just get a kickdown linkage off an '85 or older Ram to use for my 73 dart swinger 4 bbl conversion with performer intake? cause there are tons of those in the junk yards!
The linkage may not fit within the smaller engine compatment of the A body car. Lokar or similar will do great.
I use a Lokar, works great.
727 trans KD-2727HT
904 trans KD-2904HT
518 trans KD-2518HT
Garland
Believe it or not you can piece different year linkages together,and make it work. Here is a pic of the linkage at the carb to help you. I pieced the top parts together from the Junk yard, and use the original 904 bottom pieces.
