LA360 Oil Pump
Is the bushing that comes with the hardened drive the same inner diameter as a stock drive bushing? If so, any need to replace if the stock is in good condition?
Depends on the bushing.
Some bushings need to be burnished/sized after installatiion. I have also heard people talking on here about bushings that do not need to be sized.
Mopar 318,340,440,426,354 NEW Intermediate Shaft Bushing Installation Tool kit | eBay
You'll just have to measure them and see if you've got adequate clearances.
Since you must have the pan off anyway if you're replacing the oil pump & pickup, just flip the engine over and knock it out from the bottom.
