Ladder bars/stock frame/rear coilover length?
DGrace
Snow Hill, NC
There's not a lot of room so I know the options are limited. Trying to get an idea of rear coilover shock length on a '73 Dart with ladder bars and stock frame. Anybody running a similar set up?
I have no idea but, I like where you're going!
I recently installed a Moser fab 8.75 with a backbrace, Dr. Diff offset front hangers, and Mopar SS springs. I moved the rear back an inch to get a bit more tire clearance, but with the backbrace, the stock shock mounting location wouldn't work. I was in the process of fabbing up a new mount in front of the axle when......, my buddy "talks me into" putting ladder bars on. Pictures of wheels up launches danced in my head, but......there's not a lot of room behind the axle for a coilover upper mount. Even less when you move it back an inch,.......and have a backbrace. Looking at the Summit Racing double adjustable coilovers - about a 10" compressed/14" extended may work but a little input from someone who has chartered these waters would save this poor guy with 10 second dreams a little heartache.....and $!
The 10-second dream is obtainable, but it's expensive to keep it there.
I have these on all 3 cars..they are relabeled Qa1 shocks...
JEGS Performance Products 64905: Double Adjustable Coil-Over Front or Rear Shock Compressed Height: 11-5/8" | JEGS
I use adjustable mounts on the lower mounts...also use 110 lbs springs......you will need to weld new upper shock support tube across the frame rails.....
I ran a ladder/leaf setup on my 74 Swinger. I also moved the spring back one inch for clearance. A little different from coil over, but, I hole sawed holes in the trunk floor and flipped the upper shock mounts end for end.
found a few pictures...
last one was not suppose to be uploaded...lol
that duster now has a Moser Fab 875 in it...with a back brace on it...I had to get different lower shock mounts that fit the moser back brace.....
and NOW...LOL....there is a Dana 60 set to leave Stange any day now so I gotta get new lower mounts again...
Thank you. I was looking at the Summit Racing unbranded ones and thought a 10" compressed, 14" extended would be close. Nice to know someone has done it. Thank you for replying!
With the backbrace and 1" setback, my upper mount will be farther back - lower on the frame. Hoping the shorter shock will work.
you can get a ladder bar mount that has a shock mount on the back of it....
we had to move the upper support back to line up moser. Chassis Engr makes a different bracket that fits a rear with a brace on it....
dana 60 cause sooner or later the ring and pinion on a 8 3/4 will eat the teeth,,,,,just had two 8 3/4 pumpkins repaired with new ring and pinions from the other cars...they got a dana also...
that duster is scheduled to have the 360 removed and a 408 installed...plus it leaved on a transbrake....
now if the dana 60 only looked like Dana Delany......i would be hugging that rear forever....lol
I purchased the Comp Engineering lower mount that is notched for the brace. Did you use the same Jegs coilovers or did you need shorter ones? Any pics with the fab 8.75?
What length ladder bars do you use - did you use a track locator - what length? Sorry for all the ?'s - just getting as much info as possible. Thank you. Any pics too would be great!
