Lakewood Aluminum Replacement Bellhousing for Small Block Mopar
67FormulaS_273HiPo_4spd
Melbourne, Australia
I have a 67 Barracuda with a 273 Commando and 4 speed. The existing clutch arrangement for the 273 is a 9.5" clutch with 9.5" 122 tooth flywheel. I'm looking to mothball the 273 and replace with a 'stock' looking iron headed 416. I need to go to the larger 10.5" clutch which requires a 10.5" bellhousing. My question is, does the Lakewood 10.5" alum bellhousing bolt straight into a 67 Barracuda? Will it provide enough clearance for Doug's headers D453's?
The factory 10.5" Mopar bellhousing is part number 2892482 for such a swap, but I can't find one at the moment. Thanks.
The Lakewood bellhousing I can get my hands on is listed below:
Lakewood Bellhousing Kit - SB Mopar And Gen 3 Hemi
If it's as close to an original as it looks, it should fit no problem. Possible fit issues at the pinch weld, but nothing major- nothing a little hammer work won't solve, and maybe not even that.
What I don't understand (maybe I'm missing something- wouldn't be the first time) is, what is the difference in the bellhousing you listed (Lakewood Bellhousing Kit - SB Mopar And Gen 3 Hemi) and this one that Mancini also sells? (other than the "K" suffix on the part number, and $110 left in your wallet) Lakewood Bellhousing - SB Mopar And Gen 3 Hemi
The descriptions are the same.
You'll definitely want to check and correct the run out. I installed one on a 383 in a 70 Challenger. It was way off. Can't say anything for the fit in an A Body. It looks like it would work.
Professor Fate, the Lakewood Bellhousing I listed is a kit that comes with a dust cover, folk pivot, rubber boot etc.
Okay, I've done a little digging and spotted that the bell-crank stud-ball mounting point on the Lakewood bellhousing uses the later '72-'74 A Body mounting arrangement, while the '67 mounting point on my existing bellhousing uses the '67-'71 arrangement. Please refer to images below. I want to use my existing z-bar and linkages with the new Lakewood alum bellhousing, is this possible?
Thanks Dan, wow that's a huge eye-opener for all of us.
I've now managed to find a good 734 10.5" bellhousing locally and will be placing an order this afternoon to Brewer's Performance for a number of other items I need. In the past I've order a heap of stuff from you guys, everything always works as intended, service is excellent and product knowledge is second to none.
Thanks for this information about the LK7000, Dan. No wonder I haven’t been able to figure out my clutch linkage issues. I did get things working well enough to drive the car but I’m not very happy with the fit of all the parts!
I bought the big block Lakewood before seeing Dan's post. Can confirm its **** but it worked. I used a Hydraulic bearing so avoided most of the issues, home machining/massaging the ring to work without wildly throwing off runout was a biotch as well...
