mcalm1066
Member
Barn fresh disc brake package from a 75 Dart. Upper control arms,spindles,calipers,rotors,dust shields booster,master cyl. and propotioning valve. Also includes master cylinder/booster bracket and push rod as well as braces that support them. Brake lines are not included as they were cut off. Will need to be cleaned up but are solid. If you want me to ship[ I would avise we throw rotors away as well as calipers to save weight. They are very cheap at autozone. If you want them to be small bolt pattern you simply buy small bolt rotors $35 ea new.
If you want to ship my zip is 48114. $425
