Last one to post in this thread wins!
Iinsulation. Usually fiberglass insulation. R is its insulation value, R-19 is standard in a 2x6 wall. The higher the number the higher its insulation ability. I have R-36 in my ceiling. You probably have R-9 in your walls and can build with 2x4 cause of your temperate climate.
House walls are 2x6 by code and yes my shop is 2x4 but I used roxal R14 and blown in attic r32 up there .
My attic r12 to level the bottom cord of rafters two layers r20. Walls 2X6 plus 1 1/2” ridged on exterior. Shop done same way. Don’t know if it was or is worth it but it’s there. My friend works for Manitoba Hydro as an energy consultant he tells me when heating with electricity you will never recoup the cost of a triple pane window over a double pane window. Followed his advice seems to be working
The little bit of snow we had a couple of weeks ago is long gone, but I heard that there is a chance it could be back next week. :mob:
This is my yard this morning.
Since my garage is a mess figured I best get my buddy's snow mobile hood fixed so all my fiber glassing is done.
Was that back when they were still usin' those 750cc 2stroke animals? :steering:
No I remember 340 cc 440 cc there might have been a 500 can’t remember. The 600cc and over came after they upgraded the suspension from plank to something with coil over struts and trailing arms. Much better. As the tech. in the suspension got better so did the power 1200 cc is the norm. Now as is 100 mph.
Yup, that's my 75 Dart Sport, the hood stripe was painted by the po, original color was B5 from what I can tell.
My only clue was the aluminum trim at the top of the grill it’s wider on the 75 than the 74. Decals are a bit different also and some with the tail lights or in between them.
