I think you got it worse Fred. All about the weather pattern. Ive been lucky.Sorry Randy hope you'll be OK
Just my turn I guess.I think you got it worse Fred. All about the weather pattern. Ive been lucky.
Can see a haze in the air here but no real smoke or smell yet. You guy’s take it easy and be safe kSorry Randy hope you'll be OK
Wear a mask if you can Fred. It will help filter some of the crap.Hey guys got hit real bad here today with smoke worse I've seen.
Wow must be a large fire I haven't seen the news in a long time.Wear a mask if you can Fred. It will help filter some of the crap.
The smoke is now in Europe believe it or not. It's drifted that far
Good morning, yes most of Alberta is on fire , more fires in northern BC. Majorty human caused .Wow must be a large fire I haven't seen the news in a long time.
Morning Biff.Good morning, yes most of Alberta is on fire , more fires in northern BC. Majorty human caused .
Yup, it seems that most are intentionally started, what the hell is wrong with people.Good morning, yes most of Alberta is on fire , more fires in northern BC. Majorty human caused .
Certain people have been known to set fires to get work. Has happened in Manitoba before.Yup, it seems that most are intentionally started, what the hell is wrong with people.
Some speculation that the Alberta fires were started to affect the upcoming provincial election. I really hope that is not true, but nothing surprises me much these days.
I *believe* it was because they had discontinued using the right angle filter adapters, which allowed use of the longer (PH8A and similar) filters in A bodies. Without the adapters, they had to go to a shorter filter to clear everything.Fat a question for you guy’s. Why does Chrysler make the short oil filter mandatory on 318 and 360 engines?page from my owners manual
My car came without a right angle filter adapter. Needed one for header clearance with cheap *** appliance headers. The hooker headers I have now do not require a right angle adapter. Think it has to do with oil capacity maybe???????? It’s definitely not a clearance problem. Oh well only the infinite wisdom of the Chrysler engineers will know.I *believe* it was because they had discontinued using the right angle filter adapters, which allowed use of the longer (PH8A and similar) filters in A bodies. Without the adapters, they had to go to a shorter filter to clear everything.
I could be wrong; but it sounds good, right?![]()
Somebody will know. You need to get the question out there in the general population.My car came without a right angle filter adapter. Needed one for header clearance with cheap *** appliance headers. The hooker headers I have now do not require a right angle adapter. Think it has to do with oil capacity maybe???????? It’s definitely not a clearance problem. Oh well only the infinite wisdom of the Chrysler engineers will know.
In my owner’s manual it gives the mopar # 3549957 which changes up to Fram PH 43. With the adapter depending on how you have it set seems to me you would need a check valve or your engine would run with no pressure till the filter filled up.Somebody will know. You need to get the question out there in the general population.
Just got home from the dentist and looks like I'll never need a tooth brush again. LOLHey Fred, how are things going with your teeth?
That didn't take you long.Well gentlemen plant 23 is a wrap and the planter is greased and put up.
No rain for 2 weeks dried it up fast. Rain is expected of 1/4 inch tomorrow and I really need it now that the seed is in.That didn't take you long.
