spl440
Everybody's Fool
Have a LD 340 intake that I need to install a temp switch for my electric fans, is the wall thickness beside the thermostat thick enough as is just to drill and tap, or remove and have a bung welded in?
If it looks like this one have you thought about tapping a hole through under the coil mount? Or maybe using a tee off the heater hose location.
http://www.forabodiesonly.com/mopar/showthread.php?t=319349
I just went and looked at my LD340 that I will use on my 360, it doesn't look to feasible to drill and tap by the rear as those are blocked off.
I will probably get a fitting and install under the bypass hose on the front.
