The good:
This is a used Edelbrock LD 340 intake with the chrysler part number.
It has been port matched and notched and opened up for a spread bore.
All bolt holes are good
The ugly:
I personally used this on a 74’318 I had in a 66 barracuda while the 273 was out being rebuilt. I had about 500 or more miles on it with no issues. That being said I bought it with a weld in the china wall area out back and a build up near the front pin along the front gasket but nothing thru into the water / thermostat area. See photo showing underneath. Again, it held coolant, no leaks and worked perfectly and I am only selling because it needs to be used. Sitting parts do nobody any good.
I take PayPal, $250 plus actual shipping.
Located in Uncasville, CT. If you want to pick it up. If you have any questions just pm me. I am a professional welder for over 30 years. I did not fix it but it is done correctly.
Thank you, Syleng1
The ugly:
Thank you, Syleng1
