1. hoosierdaddy
    hoosierdaddy Well-Known Member
    455
    198
    Nov 13, 2008
    Central Indiana
    Local Time:
    7:33 AM
    Is it possible to flip the leaf spring front mounts without totally removing the leaf spring ? 72 Duster
  2. RAT ROD AL
    RAT ROD AL I know just enough to be dangerous FABO Gold Member
    2,632
    2817
    Jan 18, 2013
    St. James City. FL.
    Local Time:
    7:33 AM
    The bolt pattern where it bolts to the frame is offset so it only goes on the right way. But I guess you could re drill the mounting bracket.
  3. Plymouth 65
    Plymouth 65 Floorable Deplorable
    848
    706
    Jun 27, 2016
    Mich
    Local Time:
    7:33 AM
    Are you trying to lower the rear? They sell front leaf mounts that do just that. 65'
  4. Lelo Dart
    Lelo Dart *
    1,395
    380
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    6:33 AM
    Agree^^^ Flipping the hanger is not as simple as unbolting it and flipping it over.
    Are you trying to raise or lower the rear?
  5. hoosierdaddy
    455
    198
    Nov 13, 2008
    Central Indiana
    Local Time:
    7:33 AM
    Trying to lower the car but after looking closer at the mounts I've decided not to go that route . I didn't like the change of pinion angle . I have new stock leafs that haven't settled yet and I don't care for the look
  6. Plymouth 65
    848
    706
    Jun 27, 2016
    Mich
    Local Time:
    7:33 AM
    You could use lowering blocks, minimum pinion angle change. 65'
  7. hoosierdaddy
    455
    198
    Nov 13, 2008
    Central Indiana
    Local Time:
    7:33 AM
    I think I'm going the lowering block route . Seems like the best solution
  8. famous bob
    famous bob mopar misfit FABO Gold Member
    14,683
    5044
    Aug 14, 2011
    okla
    Local Time:
    6:33 AM
    I haven`t done it , but , don`t u have to switch sides when u flip them ??
