1968dartman
life is getting better!!
I need to ask a question about the 727 in my dart. When it sits the tranny leaks bad. Alao when I start the car up I have to put it in neutral so the convertor will fill up and work. Could the convertor losing it's fluid be causing the leaking? I was wondering if the fluid from the convertor coming back into the tranny is causing my leak because of overfilling? Thanks for your help.
