leaky 904 tranny oil pan
stoke
monroe, WI
Any ideas on how to fix tranny oil pan leak on my 904? I have changed the pan gasket 3 times and still leaks. What is better cork or rubber? What kind of sealant should I use, I have tried a lot of them. Just looking for suggestions Thanks, Stoke
Also if you have a steel pan check it with a straight edge to make sure its good and flat. big waves are good for surfing but not for sealing.
