Leaky Master
JGC403
Baileyton, TN
My Master cylinder is leaking out from under the lid, from the front reservoir. I recently replaced the calipers, rotors, and pads on the front and the Master cylinder. The master is re-manufactured by A1 Cardone that I got from rock auto. I took some fluid out of the reservoir, now its only about 1/3 full. This is the manual brakes on my '76 Duster. Any Ideas?
If the cover seal isn't damaged, and the clamp/bolt holds it firm, you likely got air in the rear brakes,, trapped air acts like a spring and it squits fluid up against the cover when the pedal is released, try bleeding the rear brakes...
hope it helps
