rdunnam
RDunnam
Looking at a BBS from a '73-'74 p/u to replace the lean burn carb on my '84 p/u. It has the auto choke, pull-off, cable type throttle connection, may end up having to use a kickdown cable, if and once I get it, I'll check out to see if the stock kick down linkage will work or not. The replacement has a 6218s number referenced. Will this carb work for what I'm doing, along with the other ignition mods?
