Feb 6, 2016 #1 rick4106 Well-Known Member Joined Jun 29, 2010 Messages 373 Reaction score 99 Location louisiana What spark plug does everyone check. Number 1 is easiest. Lol
Feb 6, 2016 #2 Mrmopartech Well-Known Member Joined Jun 5, 2005 Messages 2,150 Reaction score 91 Location St.Lazare Quebec Canada I check them all,if time is allowed to make sure I am getting proper fuel distribution to all cylinders,mrmopartech
Feb 6, 2016 #3 mguner How many is too many? Joined Nov 26, 2006 Messages 5,050 Reaction score 435 Location Amarillo,TX It also makes a big difference what intake manifold you are using....
Feb 6, 2016 #4 Daves69 Well-Known Member Joined Feb 20, 2011 Messages 8,218 Reaction score 7,748 Location WestOfChi I seem to recall the rear plugs tended to run rich at the track.
Feb 6, 2016 #5 I IQ52 Well-Known Member Joined Jul 30, 2011 Messages 2,870 Reaction score 3,106 Location Idaho The leanest cylinder will be the last one you check, so you have to check them all.
Feb 6, 2016 #6 BigBlockMopar BigBlockMember Joined May 1, 2011 Messages 1,769 Reaction score 839 Location Netherlands I always start with the last one...
Feb 7, 2016 #7 M moper Well-Known Member Joined Dec 27, 2004 Messages 15,912 Reaction score 2,540 Location eastern CT IQ52 said: The leanest cylinder will be the last one you check, so you have to check them all. Click to expand... Or the one you don't... In my experience, #7 or 8 are usually the leanest but you really should watch them all. It only takes one bad cylinder to break something.
Feb 7, 2016 #8 TrailBeast AKA Mopars4us on Youtube Joined Mar 11, 2011 Messages 22,958 Reaction score 13,104 Location Arizona All of them, but if I want to just do a quick check I look at the A/F ratio gauge. Seriously though, For quickie check I like to do at least one on each side if I don't have the time or whatever for all of them.
Feb 9, 2016 #9 hangn0ut Well-Known Member Joined Dec 3, 2012 Messages 747 Reaction score 127 Location rialto.ca. Single plane intake,#5 is a decent choice for leanest.
Feb 9, 2016 #10 famous bob mopar misfit Joined Aug 14, 2011 Messages 20,873 Reaction score 10,019 Location okla hangn0ut said: Single plane intake,#5 is a decent choice for leanest. Click to expand... thot it was # 7. it was on my intake , the manifold has everything to do w/ it!
Feb 9, 2016 #11 hangn0ut Well-Known Member Joined Dec 3, 2012 Messages 747 Reaction score 127 Location rialto.ca. That pair like to feed off each other.
Feb 9, 2016 #12 rick4106 Well-Known Member Joined Jun 29, 2010 Messages 373 Reaction score 99 Location louisiana we run a M1 intake
Feb 10, 2016 #13 hangn0ut Well-Known Member Joined Dec 3, 2012 Messages 747 Reaction score 127 Location rialto.ca. Is this the car running methanol? If so are you aware that reading the plugs is a whole nuther language?
Feb 10, 2016 #14 famous bob mopar misfit Joined Aug 14, 2011 Messages 20,873 Reaction score 10,019 Location okla hangn0ut said: Is this the car running methanol? If so are you aware that reading the plugs is a whole nuther language? Click to expand... have your intake flowed, then there would be no doubt about it. you might want to work on the lowest flowing runners a little.
Feb 10, 2016 #15 rick4106 Well-Known Member Joined Jun 29, 2010 Messages 373 Reaction score 99 Location louisiana Have egt sensors in collectors. Wanted to put on two leanest cylinders
Feb 11, 2016 #16 I IQ52 Well-Known Member Joined Jul 30, 2011 Messages 2,870 Reaction score 3,106 Location Idaho Yeah, well in my experience the the hottest egt cylinders are very often the richest. Because, the excess fuel in burning in the header.
