Yes, the electronic flasher plugs in as a direct fit replacement.
Just so you know, I basically started where you are now.
I bought, built and tried everything from bulbs that just install in place of the originals to light strips.
So far the light strips work best for the interior stuff like dash,overhead light and trunk light.
Prebuilt water proof panels worked best for the outside.
I like unique things here and there and also like contrasting colors, so I built mine with a bit more modern look to them with the smoked lexan.
Those LED panels are only 1/2 thick, so with a slight mod to the factory lens housings they fit behind stock lenses as well.
I wired them into a regular 1157 socket so the can be unplugged just like taking a bulb out.
Thanks for the compliment.
