[WANTED] Left Hand Thread Wheel Studs
sublime 340
Member
Alberta
Rating - 0%
0   0   0
Does anyone have any NOS or good used Left Hand Thread wheel studs for a 1970 Dart? I am after both the studs for the front disc brake Mopar P/N 2768029 and for the rear drum Mopar P/N 2070159
I got rid of all my left hand thread studs and installed all right hand studs. Any reason why you wouldn't do that, other than originality? I can't remember what I did with the left ones, I'll look tomorrow and see if I can find them.
Norm
Norm
I would like to keep the car as original as possible. I know they are a bit of a pain if anyone is unaware about left hand threads. I learned the hard way when I broke a stud off a 66 Valiant in shop class in the mid 70's.
It might be a good idea to double check which ones you need. I think A bodies used 7/16 studs, where B & E bodies use 1/2 inch studs. I may still have 1/2 inch ones that I swapped for rights, but I know for sure I have no 7/16 studs.
I have --- N.O.S. ONLY, of course --- Every Single Mopar Wheel Stud --- LEFTY and Righty ---
"A" Body, "B" and "E" Body, "C" Body, and Imperial ---
Front & Rear, Drum, & Disc !!!!!!!!!
See your P.M....... yours, Craig.....
Thanks for the note and yes mine are 7/16".
I have used set of 5.
