I'm having some "interesting" problems with a brand new 318. It's running a Comp Cams XE268 cam and Comp Cams adjustable s/s rocker arms. It doesn't seem like there's any slack in the pushrods, but on every cylinder where the lifter is sitting on the base part of the cam, I can hold the pushrod and very easily rotate it.
1. Is this normal?
2. If the lifters were preloaded, wouldn't it put enough force on the pushrods to make them at least a little difficult to rotate?
3. If the lifters aren't correctly preloaded, how likely is that to cause bent valves?
4. If the machine shop claims the valves are sticking because of "bad gas" what defense (if any) do I have?
5. If it is a machine shop problem, would it be reasonable to expect them to pay to have the engine R&R'd so they can fix it (I can't see any way to get the driver's side head off with the engine in the car)?
Thanks,
Ken
1. Is this normal?
Thanks,
Ken
