When the engine is not running the lifters bleed down, the ones you can't turn are on the higher side of the cam lobe and have pressure on them. I wouldn't use any additives. With the engine idling push down on the rocker arm on top of the push rod and see if you can push the lifter piston down, you have to push hard so put on some gloves and when it goes down it will clack loud so you know it's working.
