^^I would lean towards this as well. If your alternator is "dropping out" at low idle, there still should be plenty of battery voltage. Start by reading the infamous MAD article, and make some voltage tests
MadElectrical.com - Electrical Tech
This one on ammeters
Catalog
There's a simplified diagram in the article which illustrates primary power distribution in these cars, and points up a few places they fail
Follow along:
The FIRST big place of voltage drop problems is the bulkhead connector. Notice that power comes off the battery, through the fuse link (RED) and through the bulkhead connector
Next for problems is the ammeter, the terminals themselves as well as the ammeter internally
Next down the line, in the BLACK ammeter lead is the WELDED SPLICE. This is RARE but it has happened. Notice that splice branches off to headlights, the ignition switch feed (also for accessories!!) and the "hot" buss to the fuse panel (brake lights, etch). If that splice comes apart, you will have drop problems.
Next is in the fuse panel, poor connections at fuses, etc.
Only way to FIND this is to get a multimeter, and make voltage tests. Compare "what you have" down the line, at the various points............to battery voltage.
Also, in this particular case, the drop from the alternator output stud, from there to and through the bulkhead (BLACK) and back to the ammeter can be a factor.
