iw378
I pulled off my 1406 to try a holley 1850 on my 318. Anyways I have been tinkering with setting the secondary idle screw ( the one underneath ). The carb to intake gasket is wetter than heck. What would be causing this.
The gasket is gettting soaked from the inside out. Also any good tips for adjusting the secondary idle screw. The carb seems to run fine while driving, the A/F is around 13.5 to 14.5
but at idle it is 11.9
