hotrodbill
New Member
I have a '78 Dip, that I am having trouble with.
I am pretty sure that it has a Lockup 904 trans, and the problem is....it's locked up.
More specifically the Converter is locked up, when you put the car into gear it dies the same as if you were to let out a manual clutch.
(I have 100% eliminated any engine problems causing this condition, I know it's the tranny at this point.)
Now, what I would like to know, is what years did they make this transmission because I would like to find a replacement. I will assume the "lock-up" is hydraulically engaged.....it's not electronic.
And YES, I want to stick with a lockup converter transmission.
I have sourced a '77 model in a junkyard (same body style car), but at $150 and I have to pull it.....I'd rather not be stuck with something thats not a direct replacement. All the other cars are mid '80s or later.
Any help appreciated.
