Lokar throttle cable/kick down
mopardude318
Gilroy, Ca
I'd like to use one of these to eliminate the factory bracket and cables...Is there a complete kit to get the throttle cable and kick down cables, and the necessary hardware and brackets? What do you guys use? Where do you get them? Links? Part numbers?
I used the lokar kickdown, 24" universal throttle cable, and had to buy the bracket for it to all work together. I think the bracket part was LKR4000? It was really easy to install and set up.
Thanks. Was this all for a small block?
Just keep in mind with the TV cable hook up a return spring to the bellhousing from the lever to return it. Good insurance.
Throtle
TC-1000HT 24" Stainless Steel Hi-Tech Throttle Cable
TC-1000HT36 36" Stainless Steel Hi-Tech Throttle Cable
TC-1000U 24" Universal Black Throttle Cable
TC-1000U36 36" Universal Black Throttle Cable
stainless kickdown
Chrysler 727 KD-2727HT
Chrysler 904 KD-2904HT
Chrysler 518 KD-2518HT
KDP-2727HT Polished Hi-Tech Chrysler 727 Kickdown Kit
KDP-2904HT Polished Hi-Tech Chrysler 904 Kickdown Kit
KDP-2518HT Polished Hi-Tech Chrysler 518 Kickdown Kit
springs and bracket
SRK-4000 Stainless Steel Carburetor Bracket and Stainless Springs
