dodgeboy
I bought this 73 dar in mo over ten years ago with a blown 6 cyl.first thing thing done was changing over to a 71 front clip(not a fan of the beak).then bought a rusted beyond repair 72 dart and got the v8 k member,engine ,trans from it sent it to the grave yard,then picked up a failed drag car build for the disc brakes and the 9 inch ford rearend.and sent it down the road .then got a good deal on a 360 magnum motor from a fellow member on here.then got a smoking deal on a reverse pattern 904 with a small stall converter.the only new parts I have bought for it so far are motor/trans mounts and new stainless brake /trans lines.finally got around to dropping the engine/trans in her tonight.its gonna be a slow process as I get very little opportunity to be able to work on it.
