I have the complete set up with brackets . needs carpet but it is complete. The shifter is a a competition hurst. Push down and over for reverse. You can not miss gears with this weirdly bent factory shifter. All the parts are here even the very hard to find side cover for the console.
I Sold the Duster shell/body and no longer need the drive line. I have from the rad. back to the end of the drive shaft. complete 4 spd. set up also available. Every factory restored nut and bolt is here for the setup including all boots and clips. Trans is fresh also a heavy cut and neutral balanced flywheel from a GTS . Make me an offer for what you need. Here are some pics from a while ago when it was being fitted in the car. I had several and kept the best pieces. chrome is not perfect but will clean up good for a nice driver. new wood is here for the top and wood balls
So if you need it all its here. make me an offer I can't refuse. it needs to go. I will split it up.
