Looking for a few things...
GhostFish
Illinois
For a 66 Cuda:
Original working horn
Headliner rods(bowties?) and other parts (I'm missing it all so I'm not sure what all I need there)
Rear driver side window regulator+handle
Headlight buckets and trim rings
Windlace/Weatherstripping for both doors (or advice on where to get it)
Thanks FABO guys!
I have the head light mounting buckets, send me a pm if interested and I can get pictures :glasses7:
I have the headliner bows and a related trim if you still need that! PM if your in need, Geof
Hot damn, you guys are quick. PMs sent and thanks for the help!
I'm still looking for the regulator+handle for the right rear and the original working horn unit.
@2manymopars - Your PM box is full. Let me know when you get it cleared out so I can get you my email addy. I'll get back with you guys asap.
For a 66 Cuda:
Thanks FABO guys!
you can go a couple of different way here. $130.+ for factory correct
or $2-3 a foot from a different supplier. look up pinchweld seals
I just googled it an there's the first hit that looks close
http://www.jenkinsrubber.com.au/?stg=62
I know I did mine first time with 5/8th bulb seal and it was too big(it held the door out in the closed position about 3/16th of an inch at the door latch side). I ordered 20 ft of 1/2 and it fit MUCH better. 10ft(about 8.75 really) per door for a convertible so a hard top should be similar in length.
@66Dvert Thanks, I will definitely be looking into jenkins then.
