RustyRatRod
Caput villa stultus
24x28x12 shop. Looking for suggestions for a decent gable vent fan that won't put me in the poorhouse to help with the sweating concrete floor. Thank you drive through.
Long as it's single phase, I can wire it. But my fabrication skills are lacking. lolCan you build it? You want a door/ dampers for weather? Can you build those? Can you wire 240V to it? Not for high power, but if you find a junk outdoor unit of an AC/ heat pump, you could use the outdoor fan/ entire top off the unit to mount the fan. My basement exhaust fan, I actually converted to a 120V motor. But I got lucky. Many of those setups use a lower RPM motor for noise abatement, so you must pay attention to motor RPM. For 'xample, say it's a 1/3 hp. But A 1/3HP EG say, 900 RPM motor, those fan blades will overload a 1/3HP that runs at higher RPM
For a damper/ door, that could be simple......a simple hinged door with a hand actuator rod that you can raise and lower, etc.
