[WANTED] Looking for aluminum driver side door peak molding and rear bumper back up light assembly for dart.
67Abody
Active Member
CO.
Rating - 0%
0   0   0
Hello,
Looking for a 66 - 67 dart chrome rear bumper back up light assembly with good chrome on bezel that shows through on face of bumper.
Also an aluminum driver door peak molding (not belt molding against glass) PN# 2807646-7 Very nice used or N.O.S. thanks. (Passenger side may be the same but not sure).
Thank you for any help.
Just for clarity.
These are the parts you are looking for?
Oh Okay, thank you
I was able to find b'ups but still need the driver door aluminum peak molding and two seat medallions. thx
Thanks so much for any help you can give.
Also need the flat metal backing plates for both.
I believe the "backing plates" are still there. I only need the seat frame and am willing to part with the medallions including "backing plates ". As for condition they look almost perfect to me. I can take any pics necessary. DM me if you want to proceed.
Thank you
When removing the rear plates bend the teeth up or you will break off the posts. If the teeth break off you can use a speed nut to sandwich the rear plate to the Upholstery
Haven't laid eyes on the rear plates yet. The burlap cloth is obstructing an inspection ? I'm confident they're present.
Thanks for the heads-up.
Thank you
That's great if the medallions are in good shape with the backing plates. I have seen some people razor blade out the complete section from the old seats. If you do that it will save you time and I can take it from there. Yes I would like to proceed to acquire them. Let me know the cost and payment method. thank you for your help.
Thank you for your help!
