Reddartowner
UCF Alumni....Go Knights!
I'm looking for someone who has fully degreed a Comp Cams XE262H cam in a big block (preferably a 383, but any B motor would be fine). I need the lift vs. crank position data so I can input it into an AutoCAD file I built to check piston to valve clearance for a 383 I'm building. I want to check the clearance before I have my new heads shaved .030 to bring up the compression. I could bolt the heads on, check the clearance, and then send them to the machinist to have them cut, but it would be nice to not have to waste a head gasket and a bunch of time if I can do this mathematically..... As mild as this cam is, I don't think I'll have a problem, but I'd like to know BEFORE I have the heads cut.
So, anyone have this data..?
Thanks.....
Thanks.....
