looking for diagram of a '68 steering coulmn
res1vw21
It's only metal
Renton Wa
Well I am looking for a diagram of how a '68 A body floor shift column goes together, on all my other columns there is a set screw that holds the lower sleeve on, on this sleeve there isn't a hole for the screw, does that mean it just floats? Thanks a bunch guys and gals.
The top/bottom collar are held on by the 2 square headed bolts that have a cerrated nut on top. You can see it in the top of my 1st pic at about 12 o'clock. These fit into square-ish holes in the lower column collar and get CAREFULLY tightened. In the lower pic you can kinda see them on the towel.
