daddio4048
Daddios72
Purchased a 72 340 Duster with a built motor & one tore down. Problem is that the one tore down did not have the main caps.Where can I find these ?
I'm not 100% sure that 273/318 caps are the same.
the 273/318 caps will fit, they are shorter versus 340 caps. have to use 273/318 bolts to make them work. go to a machine shop and see if they have some caps. most shops save main caps for this reason. or find a blown up engine and rob caps off it. still have to align bore mains.
Thanks Perf. That was how I remembered it. The bore size and bolt size and placement are the same, but the cap is a little weaker (thinner) and if you use a windage tray you want to check the clearance on the crank.
