Here's the deal....
I pulled the intake off my 340 last week only to find the expected. #6 intake lobe was ground to a pulp! I pulled the heads off and then pulled the engine, turns out some "Bananna-Head" installed the valves with his eyes closed. The stem hights were all over the map. I sent the heads out to have them redone. Got them back all freshend up and ready to go with new springs locks and retainers 1.660/120# found the grind I like from Lunati pn#60404 So needless to say after all that I get a call from a friend, he has 426 stoker all fresh'ned up with the dyno sheet in his hand, look'n to sell me because he is going to build a W9 headed monster. The 426ci made 528ft pounds @4800rmp! and close to 500hp! complete with TTi headers for under 6000k I called Dynamic converters and they will build me a verter for $600.00 Should I stroke the Scamp for daily abuse? or what? Are they reliable for a weekend warrior? I don't mind drop'n the coin. just looking for some input. Btw, Callies crank 4" eagle rods (I beams)and custom JE dished pistons @ 10:0.1 cr with fully ported "X" heads Comp's mechanical roller cam, lifters, and rockers Single plane "Victor" Air-gap with Holley "HP" 750 carb. Sounds like a 440 on crack! it was in a Demon 4-speed that went 11.00 in the quater with 28" tall tires. I am just look'n to put it behind my "built" 904 with the Dynamic 3800 stall and 3:23.1 on stock 14" ralleys.... Any comments?
