Looking to go from Rallye 14X6 to Cragar SS - 1973 Dart Sport 340
TRWRacing
Chicago
Hi,
Thanks in advance!!
Eric
1973 Dodge Dart Sport 340 with stock brakes and suspension
Current setup:
14" Rallye wheels with Cooper Tires
Front tires 215/70 R14
Rear tires 235/60 R14
New ESPO stock XHD height 6 leaf springs to be installed at the same time.
Will Cragar SS fit?
Cragar 1425728402B Cragar 08/61 S/S Super Sport Chrome Wheels | Summit Racing
Tire size?
Wheel Diameter:
14 in.
Wheel Width (in.):
6.00
Wheel Size:
14x6
Wheel Bolt Pattern (application):
  • 5 x 114.3mm
  • 5 x 120.65mm
  • 5 x 4 1/2 in.
  • 5 x 4 3/4 in.
  • 5 x 5 in.
Wheel Material:
Steel/Aluminum
Designed for Dually Truck:
No
Wheel Face Color:
Chrome
Wheel Face Finish:
Chrome
Wheel Barrel/Lip Color:
Chrome
Wheel Barrel/Lip Finish:
Chrome
Manufacturers Wheel Series:
Cragar S/S Super Sport Series
Backspacing (in.):
3.38
Offset:
-3.00mm
Wheel Construction:
2-piece
TPMS Sensor Compatible:
Yes
Beadlock Included:
No
Beadlock Functional:
No
Lug Nut Seat Style:
Shank
Lug Nut Shank Length (in.):
0.80
Lug Nut Shank Diameter (in.):
0.69
Washer Outside Diameter (in.):
1.25 in.
Hub Centric Ring Compatible:
No
Center Bore Diameter (in.):
3.58
Center Bore Diameter (mm):
90.93mm
Center Cap Included:
Yes
Lug Nuts Included:
No
Small Diameter Lug Nuts Required:
No
Good choice, Cragars look good on everything! Although I'd go 15". More tire choices, and IMO...just look better.
15x8 with 4.25 out back is really nice on your car. A 245/60/15 fits really nice. You would have to go smaller up front and can stick to that 14x6 if you want too 205/70/14 is very common, although a 15 would be a little better
That 4.25 Backspace was recommended by a wheel company. Call Cragar
In my opinion, get enough backspacing to keep the tires tucked in will be important. I tried some aftermarket 6" wide wheels 40 years ago on my Dart Sport and the tires were under the wheel opening. I mean the fender would sit right down on top of the outside edge of the tread.
I ended up using chrome rimmed Rallye wheels with painted centers.
This is the only picture I have with those wheels. 8" rears with L60 Goodyear Polyglas GT and 6" front with F70 Goodyear Polyglas GT.
Yes they fit good...14" on burgundy one with G60....15" on the yellow one with 275 drag radial...no mods ..duster has open wheel well
If you didn't want to run your torsion bars up so high you could always go to a 205 /75/ 14 and it sits about an inch and a half higher maybe two..but I love the level look..just raised mine up some...adding wheel well trim now....really love those twisters...I'm adding scoops also...
