Hi,
Thanks in advance!!
Eric
1973 Dodge Dart Sport 340 with stock brakes and suspension
Current setup:
14" Rallye wheels with Cooper Tires
Front tires 215/70 R14
Rear tires 235/60 R14
New ESPO stock XHD height 6 leaf springs to be installed at the same time.
Will Cragar SS fit?
Cragar 1425728402B Cragar 08/61 S/S Super Sport Chrome Wheels | Summit Racing
Tire size?
Wheel Diameter:
14 in.
Wheel Width (in.):
6.00
Wheel Size:
14x6
Wheel Bolt Pattern (application):
Steel/Aluminum
Designed for Dually Truck:
No
Wheel Face Color:
Chrome
Wheel Face Finish:
Chrome
Wheel Barrel/Lip Color:
Chrome
Wheel Barrel/Lip Finish:
Chrome
Manufacturers Wheel Series:
Cragar S/S Super Sport Series
Backspacing (in.):
3.38
Offset:
-3.00mm
Wheel Construction:
2-piece
TPMS Sensor Compatible:
Yes
Beadlock Included:
No
Beadlock Functional:
No
Lug Nut Seat Style:
Shank
Lug Nut Shank Length (in.):
0.80
Lug Nut Shank Diameter (in.):
0.69
Washer Outside Diameter (in.):
1.25 in.
Hub Centric Ring Compatible:
No
Center Bore Diameter (in.):
3.58
Center Bore Diameter (mm):
90.93mm
Center Cap Included:
Yes
Lug Nuts Included:
No
Small Diameter Lug Nuts Required:
No
Thanks in advance!!
Eric
Current setup:
Will Cragar SS fit?
Tire size?
Wheel Diameter:
14 in.
Wheel Width (in.):
6.00
Wheel Size:
14x6
- 5 x 114.3mm
- 5 x 120.65mm
- 5 x 4 1/2 in.
- 5 x 4 3/4 in.
- 5 x 5 in.
Steel/Aluminum
No
Wheel Face Color:
Chrome
Wheel Face Finish:
Chrome
Chrome
Chrome
Backspacing (in.):
3.38
Offset:
-3.00mm
Wheel Construction:
2-piece
Yes
Beadlock Included:
No
No
Lug Nut Seat Style:
Shank
0.80
0.69
1.25 in.
No
3.58
90.93mm
Yes
Lug Nuts Included:
No
No
