Here's the THING. Your were "back there" around the wring, the bulkhead connector. You might have a 'somewhat' connection, and know you have bumped it loose
You might have bumped it WHILE messing with the bolt, but the bolt / distributor per se is not causing the "no crank" problem
1............IF YOU HAVE the dreaded interlock, BYPASS it, or it will give you future trouble. Look at these threads:
http://www.forabodiesonly.com/mopar/showthread.php?t=14304
http://www.forabodiesonly.com/mopar/showthread.php?p=1969624169
http://www.forabodiesonly.com/mopar/showthread.php?p=1705079
In that reset, the connector has two "yellowish" wires---with tracer. Cut those two and permanently splice them together.
2............If it still won't crank, it's time to take a breather
get yourself a shop manual. Closest we have for download (free) is a 73. There may be some wiring differences........
http://www.forabodiesonly.com/mopar/showthread.php?t=244981
More of the same here:
http://www.mymopar.com/index.php?pid=31
and MyMopar has simplified but sometimes easier to follow diagrams. However they do not show all connectors, and are sometimes incorrect
http://www.mymopar.com/downloads/1974/74DartA.jpg
http://www.mymopar.com/downloads/1974/74DartB.jpg
3.........If you don't have same, "arm yourself." Go to RadShack or make them......get a bag or two of clip / test leads. Get a multimeter. Buy a 12V test lamp, and if you don't have one, buy an inline spark tester for checking for spark on your ignition.
When you get "all this," time to learn to troubleshoot.
"Workflow" for the cranking signal comes from the ignition switch, through the bulkhead, and if equipped goes through the dreaded seat belt interlock.
Next it goes to one of the two "push on" quick connectors on the starter relay. But the starter relay has a GROUND terminal, the SECOND "push on" terminal.
This second terminal goes down to your neutral safety switch (middle terminal) on the transmission with an automatic, and if you have a manual gearbox, with a clutch safety switch, that wire goes back in through the bulkhead, to the switch on the clutch pedal
EITHER OF THE ABOVE must provide a "ground" for the relay terminal
4........How to tell? EASY
"Rig" your test lamp to the yellow wire going to the starter relay "quick connect" terminal. The remaining terminal will go down the firewall to the automatic. Twist the key. No crank? Hear a click? Does the lamp light? If not, you are not getting "crank" power
Most likely a bad connection through the bulkhead, or that seat belt interlock.
If you DO have power? and the relay does not click, or the engine does not crank,
TIME TO check the second terminal. Remove that wire, hook a clip lead temporarily to ground. WATCH IT the car WILL START if it's in gear. MAKE SURE. Try the "key" does it crank now? Yes?
If so, you have a problem with the wiring or the neutral safety switch or linkage adjustment
Hook the wire back up. Hold the key to "start" wile wiggling the shifter lever from park to neutral. Anything? Click? Nothing? Wiring, bad neutral safety switch, or bad connector at the switch
5.......Other problems. The relay itself can be bad. How to test?
Take a screwdriver and jumper across the two "large" exposed connectors on the relay. Does the starter operate? Yes? Relay or relay wiring troubles.
Now unhook both "quick connectors" from the relay. Clip one terminal to ground. Take a screwdriver or clip lead. Jumper from the large exposed stud over to the remaining relay quick connect terminal. Does it crank? Yes? wiring
No? Bad relay
IF YOU jumpered the big terminals and no crank, now you are into bad battery connections, bad battery cables, bad wire down to the solenoid or bad starter
